Custom Reconciliation with Groovy Connector and REST API
Hello OpenIAM Team,
We are currently using OpenIAM Community Edition 4.2.1.14 with a custom provisioning architecture based on a Groovy connector, Kafka, and microservices.
Our existing connector handles provisioning operations, but it does not support searching for or retrieving users and their assigned roles from the target application.
We would like to implement user and role reconciliation by querying the target application’s REST API directly from a Groovy script, without modifying our existing provisioning architecture.
Our goal is to keep OpenIAM as the source of truth, comparing the user’s assigned access in OpenIAM against the actual roles in the target application.
We have the following questions:
Can OpenIAM reconciliation retrieve users and roles directly through a custom Groovy script, without implementing search operations in the existing connector?
What data structure or format does OpenIAM expect from the reconciliation script? How should the users and their assigned roles retrieved from the REST API be returned so that OpenIAM can process and compare them?
Are there any working examples or documentation for implementing this type of custom reconciliation in OpenIAM 4.2.1.14?
Thank you for your guidance.
