Hi @ameet_shah ,
¿I hope you are doing well?
We are currently analyzing how to allow privileged administrators to manage active user sessions in OpenIAM.
The requirement is that administrators should be able to:
- List or identify active user sessions.
- Terminate active sessions for specific users in OpenIAM, either:
- one specific session, or
- all active sessions for a given user.
- Revoke the related OAuth/OIDC tokens if required.
- Audit the administrative action.
Could you please confirm whether OpenIAM provides any out-of-the-box functionality to cover this requirement, or part of it, from the Administrative Webconsole?
What we have found so far:
Regarding session and token visibility, we found that some information can be obtained from the database tables:
-AUTH_STATE
-OAUTH_TOKEN
We also noticed that some token information can be viewed from the UI under the user-related menus, and that token revocation appears to be available from the UI or through the existing token revocation endpoint. However, for session termination, Is deleting directly from data base a supported method i don´t thing so.
we would prefer to avoid unsupported operations such as directly deleting database records. We also understand that simply revoking tokens through the /revoke endpoint may not be equivalent to performing a full user logout, especially if OpenIAM maintains server-side sessions, SSO state, or application session information. In a previous discussion, you mentioned the existence of:
AuthenticationService.globalLogoutRequest(...)
Additional technical context:
As additional context, we inspected our deployed OpenIAM binaries and found that openiam-esb.jar contains the following class:
BOOT-INF/classes/org/openiam/esb/core/service/impl/AuthenticationServiceImpl.class
This class includes a globalLogoutRequest(…) method with the following signature:
void globalLogoutRequest(org.openiam.base.request.LogoutRequest request)
The LogoutRequest DTO is available in:
BOOT-INF/lib/openiam-common-intf-4.2.1.15.jar
as:
This DTO appears to contain the following fields:
userId
patternId
token
sessionId
With the corresponding accessors:
getUserId / setUserId
getPatternId / setPatternId
getToken / setToken
getSessionId / setSessionId
Inside AuthenticationServiceImpl.class, we also observed references to:
getUserId
getPatternId
getSessionId
newLogoutEvent
LOGOUT
LOGOUT_EXCEPTION
Error while logout
This suggests that globalLogoutRequest(…) may be the internal logout event mechanism used to invalidate a user session based on userId, sessionId and possibly patternId.
We have also seen public OpenIAM Javadoc references showing that AuthenticationServiceImpl exposes a method named:
void globalLogoutRequest(LogoutRequest request)
although the exact DTO package appears to differ from the one used in our deployed version. [download.openiam.com]
Questions:
- Is there any out-of-the-box option in the Admin UI to invoke this logout functionality?
- ¿Could you please clarify whether this service is intended to?
- invalidate the OpenIAM user session,
- trigger a global logout event,
- revoke OAuth/OIDC tokens,
- and create the corresponding audit events?
- Can this method be used to terminate:
one specific user session?
all active sessions for a given user?
3. If there is no out-of-the-box UI option, what is the recommended approach?
At this stage, the following possible approaches come to mind… is there anything similar to
Is there any supported REST API endpoint for this functionality?
creating a custom internal REST endpoint,
invoking the service from a Groovy script.
using a custom OpenIAM resource or URI,
or using another supported extension point.
Could a Groovy script be used in combination with a custom endpoint or OpenIAM resource to call this service?
Is there any official documentation, real example, code sample or recommended implementation pattern for this requirement?
Kind Regards.
Mlmoreno.
