Hello @ameet_shah
Thank you for taking the time to review my question and provide your feedback.
I’ve been testing a generic script as a business rule to cover scenarios where a user is onboarded, changes job position, or no longer has an assigned position.
Do you think it’s necessary for the script to explicitly handle all these cases, or does OpenIAM already cover them with the script you previously shared?
At the moment, the job role configuration is as follows:
Analista IT (Job Title)
→ Admin Role (Managed System A)
→ Analyst Role (Managed System B)
Please note that the target systems (platforms) do not have out-of-the-box connectors, so a custom connector was developed using microservices.
Additionally, we are evaluating how to handle the access reconciliation process so that it runs once per day.
The script I have been using is as follows:
import org.openiam.br.groovy.IActionExecutor
import org.openiam.base.AttributeOperationEnum
import org.openiam.common.beans.mq.RoleRabbitMQService
import org.openiam.common.beans.mq.GroupRabbitMQService
import org.openiam.idm.searchbeans.RoleSearchBean
import org.openiam.idm.searchbeans.GroupSearchBean
import org.openiam.idm.srvc.entitlements.EntitlementsCollection
import org.openiam.idm.srvc.grp.dto.Group
import org.openiam.idm.srvc.role.dto.Role
import org.openiam.idm.srvc.user.dto.User
import org.openiam.idm.srvc.user.dto.UserStatusEnum
import org.openiam.idm.srvc.membership.dto.MembershipXref
import org.openiam.idm.srvc.user.dto.UserToRoleMembershipXref
import org.openiam.idm.srvc.user.dto.UserToGroupMembershipXref
import org.apache.commons.collections.CollectionUtils
import org.springframework.context.ApplicationContext
class RecalculateAccessByCargo implements IActionExecutor {
ApplicationContext context
private static final Set<String> EXCLUDED_ROLE_IDS = new HashSet<String>()
private static final Set<String> EXCLUDED_GROUP_IDS = new HashSet<String>()
@Override
void perform(User user) {
println "========== RecalculateAccessByCargo START =========="
if (user == null) {
println "User is null. Skip."
return
if (user.getStatus() == UserStatusEnum.TERMINATED ||
user.getStatus() == UserStatusEnum.DISABLED) {
println "User terminated/disabled. Removing all roles/groups."
endDateAllRoles(user)
endDateAllGroups(user)
return
String cargoName = user.getTitle()?.trim()
println "Charge received from user.title: ${cargoName}"
if (!cargoName) {
println "user.title empty. Cannot be recalculated."
return
Role cargoRole = fetchCargoRoleByName(cargoName)
if (cargoRole == null) {
println "No parent role with name was found: ${cargoName}"
return
Set<String> expectedRoleIds = new LinkedHashSet<String>()
Set<String> certifiedRoleIds = new LinkedHashSet<String>()
Set<String> expectedGroupIds = new LinkedHashSet<String>()
buildExpectedAccessFromCargo(cargoRole, expectedRoleIds, certifiedRoleIds, expectedGroupIds)
println "Expected roles: ${expectedRoleIds}"
println "Expected groups: ${expectedGroupIds}"
reconcileRoles(user, expectedRoleIds)
reconcileGroups(user, expectedGroupIds)
addMissingRoles(user, expectedRoleIds, certifiedRoleIds)
addMissingGroups(user, expectedGroupIds)
println "========== RecalculateAccessByCargo END =========="
private void buildExpectedAccessFromCargo(Role cargoRole,
Set<String> expectedRoleIds,
Set<String> certifiedRoleIds,
Set<String> expectedGroupIds) {
* Add the parent position
expectedRoleIds.add(cargoRole.getId())
certifiedRoleIds.add(cargoRole.getId())
* If the position had direct reports
addGroupsFromRole(cargoRole, expectedGroupIds)
if (CollectionUtils.isEmpty(cargoRole.getChildRoles())) {
return
for (MembershipXref roleXref : cargoRole.getChildRoles()) {
Role childRole = fetchRoleById(roleXref.getEntityId())
if (childRole == null) {
continue
* Direct son role of the position
expectedRoleIds.add(childRole.getId())
certifiedRoleIds.add(childRole.getId())
addGroupsFromRole(childRole, expectedGroupIds)
if (CollectionUtils.isNotEmpty(childRole.getChildRoles())) {
for (MembershipXref perfilXref : childRole.getChildRoles()) {
Role perfilRole = fetchRoleById(perfilXref.getEntityId())
if (perfilRole == null) {
continue
* Perfil
expectedRoleIds.add(perfilRole.getId())
addGroupsFromRole(perfilRole, expectedGroupIds)
private void addGroupsFromRole(Role role, Set<String> expectedGroupIds) {
if (role == null || CollectionUtils.isEmpty(role.getGroups())) {
return
for (MembershipXref groupXref : role.getGroups()) {
if (groupXref.getEntityId() != null) {
expectedGroupIds.add(groupXref.getEntityId())
private void reconcileRoles(User user, Set<String> expectedRoleIds) {
if (CollectionUtils.isEmpty(user.getRoles())) {
return
for (UserToRoleMembershipXref existingRole : user.getRoles()) {
String roleId = existingRole.getEntityId()
if (!roleId) {
continue
if (existingRole.getOperation() == AttributeOperationEnum.DELETE) {
continue
if (EXCLUDED_ROLE_IDS.contains(roleId)) {
println "Role excluido, no se toca: ${roleId}"
continue
if (!expectedRoleIds.contains(roleId)) {
existingRole.setEndDate(new Date())
existingRole.setOperation(AttributeOperationEnum.DELETE)
println "Role removed because it does not correspond to the current position: ${roleId}"
} else {
println "Role is maintained: ${roleId}"
private void reconcileGroups(User user, Set<String> expectedGroupIds) {
if (CollectionUtils.isEmpty(user.getGroups())) {
return
for (UserToGroupMembershipXref existingGroup : user.getGroups()) {
String groupId = existingGroup.getEntityId()
if (!groupId) {
continue
if (existingGroup.getOperation() == AttributeOperationEnum.DELETE) {
continue
if (EXCLUDED_GROUP_IDS.contains(groupId)) {
println "Excluded group, untouchable: ${groupId}"
continue
if (!expectedGroupIds.contains(groupId)) {
existingGroup.setEndDate(new Date())
existingGroup.setOperation(AttributeOperationEnum.DELETE)
println "Group removed because it does not correspond to the current position: ${groupId}"
} else {
println "Group remains: ${groupId}"
private void addMissingRoles(User user,
Set<String> certifiedRoleIds) {
for (String roleId : expectedRoleIds) {
if (hasActiveRole(user, roleId)) {
continue
Role role = fetchRoleById(roleId)
if (role == null) {
continue
Boolean certified = certifiedRoleIds.contains(roleId)
addRole(user, role, certified)
private void addMissingGroups(User user, Set<String> expectedGroupIds) {
for (String groupId : expectedGroupIds) {
if (hasActiveGroup(user, groupId)) {
continue
Group group = fetchGroupById(groupId)
if (group == null) {
continue
addGroup(user, group)
private Role fetchCargoRoleByName(String cargoName) {
println "Looking for a job title by exact job title.: ${cargoName}"
RoleRabbitMQService roleMQService =
context.getBean(RoleRabbitMQService.class) as RoleRabbitMQService
RoleSearchBean searchBean = new RoleSearchBean()
searchBean.setDeepCopy(false)
EntitlementsCollection[] collections = [
EntitlementsCollection.CHILDRENS,
EntitlementsCollection.GROUPS
List<Role> roles =
roleMQService.findBeans(searchBean, collections, 0, Integer.MAX_VALUE)
if (CollectionUtils.isEmpty(roles)) {
println "No se encontraron roles."
return null
for (Role role : roles) {
if (role.getName() != null &&
role.getName().trim().equalsIgnoreCase(cargoName.trim())) {
println "Role found: ${role.getName()}"
return fetchRoleById(role.getId())
println "Role with name not found: ${cargoName}"
return null
private Role fetchRoleById(String roleId) {
if (!roleId) {
return null
searchBean.setKeySet(List.of(roleId))
List<Role> roles =
roleMQService.findBeans(searchBean, collections, 0, 1)
if (CollectionUtils.isNotEmpty(roles)) {
return roles.get(0)
return null
private Group fetchGroupById(String groupId) {
if (!groupId) {
return null
GroupRabbitMQService groupMQService =
context.getBean(GroupRabbitMQService.class) as GroupRabbitMQService
GroupSearchBean searchBean = new GroupSearchBean()
searchBean.setKeySet(List.of(groupId))
List<Group> groups =
groupMQService.findBeans(searchBean, 0, 1)
if (CollectionUtils.isNotEmpty(groups)) {
return groups.get(0)
return null
private void addRole(User user, Role role, Boolean certified) {
if (role == null) {
return
Date startDate = getStartDate(user)
if (certified) {
user.addRole(role, Set.of("IS_CERTIFIED"), startDate, null)
} else {
user.addRole(role, null, startDate, null)
println "Role agregado: ${role.getName()}"
private void addGroup(User user, Group group) {
return
user.addGroup(group, null, startDate, null)
println "Group agregado: ${group.getName()}"
private boolean hasActiveRole(User user, String roleId) {
return false
if (existingRole.getEntityId() != null &&
existingRole.getEntityId().equals(roleId) &&
existingRole.getOperation() != AttributeOperationEnum.DELETE) {
return true
return false
private boolean hasActiveGroup(User user, String groupId) {
return false
if (existingGroup.getEntityId() != null &&
existingGroup.getEntityId().equals(groupId) &&
existingGroup.getOperation() != AttributeOperationEnum.DELETE) {
return true
return false
private Date getStartDate(User user) {
if (user.getStartDate() != null && user.getStartDate().after(new Date())) {
return user.getStartDate()
return new Date()
private void endDateAllRoles(User user) {
return
private void endDateAllGroups(User user) {
return
