OAuth2 Token works with /idp/oauth2/userinfo but WebConsole REST API returns /openiam-ui-static/401
Hello,
I am currently evaluating the OpenIAM REST API and OAuth2 integration on OpenIAM 4.2.1.13
I created an OAuth Client according to the official documentation:
  • Create Auth Provider
  • Granting Authorization
  • API Call Examples
OAuth Client configuration:
  • Grant Type: Client Credentials (also tested with Authorization Code)
  • Auth Type: Basic HTTP
  • Scopes:
    • MTK-/webconsole/*
    • MTK-/selfservice/*
    • OAUTH_user_name
The OAuth flow itself appears to work correctly.
Client Credentials Flow
Request:
POST /idp/oauth2/token
grant_type=client_credentials
Response:
  "access_token": "...",
  "token_type": "Bearer"
Token validation:
GET /idp/oauth2/userinfo
Authorization: Bearer <token>
Response:
  "sub": "0001",
  "user_name": "system"
Authorization Code Flow
Request:
Response:
  "sub": "3000",
  "user_name": "sysadmin"
The token is also correctly stored in the OAUTH_TOKEN table and associated with the expected user.
Problem
Any call to the WebConsole REST API fails.
POST /webconsole/rest/api/users/search?deepCopy=true
Content-Type: application/json
Body:
  "from": 0,
  "size": 20,
  "principal": "sysadmin"
Response:
  "timestamp": ...,
  "status": 404,
  "error": "Not Found",
  "path": "/openiam-ui-static/401"
This appears to be an internal 401 Unauthorized that is redirected to /openiam-ui-static/401, which does not exist and therefore results in a 404.
Question
Since /idp/oauth2/userinfo successfully validates the token and resolves the correct user, OAuth itself seems to be working.
Are additional configuration steps required to authorize OAuth clients against:
/webconsole/rest/api/*
or
/selfservice/rest/api/*
endpoints?
Is there a specific API role, resource mapping, scope configuration, or OAuth provider setting required beyond what is described in the API documentation?
Any guidance would be appreciated.
Hello @Luca,
Thanks for your questions. I’ve reached out internally and will have answers for you shortly.
Hello @Luca ,
Please add the OAUTH scope-user_name to your OAuth Provider configuration. This should help ensure that the user_name claim is included in the token introspection response, allowing the reverse proxy to correctly identify the user and complete the authentication flow.
Thanks.
Hello Ameet,
Thank you for your response.
I would like to clarify that the OAUTH_user_name scope was already present in the OAuth Provider configuration before I opened this thread.
Current scopes are:
  • MTK-/webconsole/*
  • Main-Taunus-Kreis-/webconsole/*
  • OAUTH_user_name
To verify this, I generated completely new access tokens and repeated all tests.
Token validation
Authorization: Bearer CTQRoDfeGBOM01R.7UBCV3HTZlZE4rnWHMQ4_y.HwFu3nyYSdagy7oLtwhKnC2RtdOXLWXmX0A8qNO
Response:
  "sub":"3000",
  "user_name":"sysadmin",
  "auth_time":1780992128
This confirms that:
  • OAuth authentication works
  • the token is valid
  • the token resolves to the correct user
  • the user_name claim is already present
API tests
Using the exact same access token:
GET /webconsole/rest/api/profile
GET /selfservice/rest/api/profile
All requests return:
  "status":404,
  "error":"Not Found",
  "path":"/openiam-ui-static/401"
The same behavior occurs with:
  • Authorization Code Flow (sysadmin)
  • Client Credentials Flow (system)
In both cases /idp/oauth2/userinfo succeeds, while all /webconsole/rest/api/* and /selfservice/rest/api/* requests fail.
Is there any additional configuration required to allow OAuth Bearer Tokens to access the WebConsole or Selfservice REST APIs?
Thank you.
Hello @Luca,
For this issue, the OAuth client must have /webconsole/rest/api/* configured as a default scope. Without this scope, calls to the OpenIAM REST APIs may return a 401 Unauthorized response even though the token works successfully against the UserInfo endpoint.
That resolved my problem! Thank you for your support.
You are very welcome, @Luca. Please let us know if we can help with anything else.
