Hi @pradeep.bhalla,
1st Issue – Provisioning to AD (Provisioning Status: FAIL_SAVE)
Below is the log from “Connector Response”. I also attached a screenshot from AD to show that the path attribute existed.
Exception at Program.RequestHandler at invoking PowerShell - ’ System.Management.Automation.RuntimeException: Cannot run user creation as calculated path attribute (‘OU=Switzerland,OU=Users,dc=dmfiam,dc=ch’) either does not exist or is not of container or OU type (or not a root DC location) —> System.Management.Automation.RuntimeException: Cannot run user creation as calculated path attribute (‘OU=Switzerland,OU=Users,dc=dmfiam,dc=ch’) either does not exist or is not of container or OU type (or not a root DC location) — End of inner exception stack trace — at System.Management.Automation.Runspaces.PipelineBase.Invoke(IEnumerable input) at System.Management.Automation.PowerShell.Worker.ConstructPipelineAndDoWork(Runspace rs, Boolean performSyncInvoke) at System.Management.Automation.PowerShell.Worker.CreateRunspaceIfNeededAndDoWork(Runspace rsToUse, Boolean isSync) at System.Management.Automation.PowerShell.CoreInvokeHelper[TInput,TOutput](PSDataCollection1 input, PSDataCollection1 output, PSInvocationSettings settings) at System.Management.Automation.PowerShell.CoreInvoke[TInput,TOutput](PSDataCollection1 input, PSDataCollection1 output, PSInvocationSettings settings) at System.Management.Automation.PowerShell.Invoke(IEnumerable input, PSInvocationSettings settings) at ConnectorRequestRunner.Workers.PowershellWorker.RunPowershellScript(String scriptPath, MessageInfo openIAMRequest) ’
2nd Issue – Attribute Mapping
Please see my answers in bold.
Have you defined the new attributes in the CSV file and are looking to map them through the transformation script so they get saved in OpenIAM? Yes
Let us know the specific attributes and your intended outcome, and we’ll guide you through the adjustments. DEPARTMENT, FUNCTION, EMPLOYEE_TYPE, SUPERVISOR and ORGANIZATION.
I attached here the transformation script that we are using.
Transformation Script.txt (5.7 KB)
In addition to the above issues, in our transformation script, we add a condition there to sanitize the email address to convert German and Spanish letters into ASCII friendly equivalent, but we got a VALIDATION ERROR instead.
Thank you in advance for your assistance and support.
