OpenIAM provides several deployment options for both on-premises and native cloud deployments. In this section, we provide more details on the two most common deployment types.
Hello,
I see that version 4.2.1.13 is now available.
I’m currently running OpenIAM CC 4.2.1.12.
Is there any documentation available that explains how to upgrade to this new version?
Thank you in advance for your help.
Hello @MarVI,
The latest version is 4.2.1.14 – I will update the Getting Started Guide links shortly.
Instructions on how to upgrade can be found in our docs at this link: Upgrading from versions 4.2.1.x to version 4.2.1.14 in RPM
Please let me know if you have any questions.
Thank you for your reply.
I’ll proceed with the upgrade then.
However, after checking the env.conf file under the upgrading section, I noticed the following lines:
############ UPGRADING #############################
# This variable is used by upgrade script only
export OIAM_TYPE="enterprise"
export UPGRADE_TO_VERSION=""
export VAULT_VERSION_UPGRADE=""
export OIAM_TYPE=enterprise
I haven’t modified this part of the file, so I don’t understand why the type is set to enterprise.
Should I replace it with community, or is this variable not yet used in the current version?
Hello @MarVI, you can keep the configuration file as is and continue with the upgrade.
