[2026.5.2][RPM upgrade] openiamrepo.tar.gz extracted from wrong path → mod_openiam not installed → httpd (reverse proxy) fails to start
Environment
- OpenIAM 2026.5.2, upgraded from 2026.5.1
- Deployment: RPM, single-node all-in-one
- OS: RHEL 9.8 (el9), x86_64
- DB: PostgreSQL 18.4 · Search: OpenSearch · Vault local
- Upgrade run: online mode (
openiam-cli upgrade/utils/upgrade.sh), answeredYto the internet-availability prompts
Severity / Impact: High — after the upgrade completes, the Apache reverse proxy (mod_openiam) is uninstalled and cannot be reinstalled, so httpd fails to start and the entire web UI (:80/:443) is unreachable. Backend services come up fine, but nothing is served through the proxy. Reproducible on every RPM upgrade to 2026.5.2.
Summary
The upgrade script downloads openiamrepo.tar.gz (which contains mod_openiam-2026.5.2.el9.x86_64.rpm and other RPM dependencies) to one directory but tries to extract it from a different, hard-coded directory. The extraction fails silently, openiamrepo/ stays empty, the subsequent mod_openiam install fails, and httpd won’t start.
Steps to reproduce
- RPM single-node install of 2026.5.1.
- Set
UPGRADE_TO_VERSION="2026.5.2"inenv.conf, runopeniam-cli upgradein online mode. - Let it complete; then
systemctl status httpd.
Expected: mod_openiam-2026.5.2 installed, httpd running, UI reachable.
Actual: openiamrepo/ empty, mod_openiam not installed, httpd dead.
Root cause (path mismatch in utils/upgrade.sh)
Download destination is
$HOME_DIR(/usr/local/openiam):# upgrade.log+ DEST_FILE=/usr/local/openiam/openiamrepo.tar.gz+ curl -k -q .../dependencies/el9/openiamrepo.tar.gz --output /usr/local/openiam/openiamrepo.tar.gzThe download succeeds (curl reaches 100%, ~1215 MB).
Extraction reads from
$ARTIFACTS_PATH(/usr/src), not$HOME_DIR:# upgrade.sh line 152tar -xvf $ARTIFACTS_PATH/openiamrepo.tar.gz --directory=$HOME_DIR# upgrade.log (resolved)+ tar -xvf /usr/src/openiamrepo.tar.gz --directory=/usr/local/openiamtar: /usr/src/openiamrepo.tar.gz: Cannot open: No such file or directorytar: Error is not recoverable: exiting now -
Downstream failures caused by the empty repo:
+ yum install /usr/local/openiam/openiamrepo/mod_openiam-2026.5.2.el9.x86_64.rpm -yCan not load RPM file: /usr/local/openiam/openiamrepo/mod_openiam-2026.5.2.el9.x86_64.rpm.Could not open: ...+ systemctl restart httpdJob for httpd.service failed ...# httpd -t:Cannot load modules/mod_openiam.so into server: .../mod_openiam.so: cannot open shared object file -
For contrast,
backend.tar.gzandfrontend.tar.gzdownload and extract from/usr/local/openiam/(consistent paths) and apply correctly — onlyopeniamrepo.tar.gzuses the mismatched$ARTIFACTS_PATH.
Suggested fix
Make the openiamrepo.tar.gz extraction source match its download destination (use $HOME_DIR like backend/frontend), or download it to $ARTIFACTS_PATH consistently. i.e. tar -xvf $HOME_DIR/openiamrepo.tar.gz --directory=$HOME_DIR.
Workaround (verified)
cd /usr/local/openiam
sudo curl -k -o openiamrepo.tar.gz \
https://download.openiam.com/release/enterprise/2026.5.2/dependencies/el9/openiamrepo.tar.gz
sudo tar -xf openiamrepo.tar.gz --directory=/usr/local/openiam
sudo yum install /usr/local/openiam/openiamrepo/mod_openiam-2026.5.2.el9.x86_64.rpm -y
sudo systemctl restart httpd && httpd -t
After this, httpd starts and the UI is reachable again.
Secondary issue (same upgrade, likely related) — batch-task-manager not deployed on RPM
The 2026.5.2 payload (openiam.tar.gz) ships ./etc/systemd/system/openiam-batchtask.service (+ .timer) and installs services/bin/batch-task-manager.jar, but on a single-node RPM all-in-one the unit is not installed/enabled:
systemctl status openiam-batchtask.service
Unit openiam-batchtask.service could not be found.
So the new batch-task-manager microservice never starts, and its first-start Flyway migration into the new batchtasks DB (copying openiam.BATCH_CONFIG → batchtasks.BATCH_CONFIG) does not run. The upgrade notes describe deploying this service only via the Helm/ArgoCD (container) path, with no RPM equivalent documented. Request: document + automate the RPM deployment (install & enable openiam-batchtask.service).
