Hello ameet_shah, iam
Does this box have Internet access ? \[y/n\]:
Reconfigure env.conf
openiamrepo.tar.gz exists. Continue…
backend.tar.gz exists. Continue…
frontend.tar.gz exists. Continue…
openiamrepo/
openiamrepo/mariadb/
openiamrepo/mariadb/perl-MIME-Base64-3.15-396.el8.x86_64.rpm
openiamrepo/mariadb/perl-Math-BigInt-1.9998.11-7.el8.noarch.rpm
openiamrepo/mariadb/perl-Pod-Usage-1.69-395.el8.noarch.rpm
openiamrepo/mariadb/mariadb-backup-10.3.39-1.module+el8.8.0+19673+72b0d35f.x86_64.rpm
openiamrepo/mariadb/perl-Net-SSLeay-1.88-2.module+el8.6.0+13392+f0897f98.x86_64.rpm
openiamrepo/mariadb/perl-IO-1.38-422.el8.x86_64.rpm
openiamrepo/mariadb/perl-DBD-MySQL-4.046-3.module+el8.1.0+2938+301254e2.x86_64.rpm
openiamrepo/mariadb/mariadb-errmsg-10.3.39-1.module+el8.8.0+19673+72b0d35f.x86_64.rpm
openiamrepo/mariadb/perl-interpreter-5.26.3-422.el8.x86_64.rpm
openiamrepo/mariadb/perl-Term-ANSIColor-4.06-396.el8.noarch.rpm
openiamrepo/mariadb/perl-Time-Local-1.280-1.el8.noarch.rpm
openiamrepo/mariadb/perl-Unicode-Normalize-1.25-396.el8.x86_64.rpm
openiamrepo/mariadb/perl-Scalar-List-Utils-1.49-2.el8.x86_64.rpm
openiamrepo/mariadb/perl-Mozilla-CA-20160104-7.module+el8.3.0+6498+9eecfe51.noarch.rpm
openiamrepo/mariadb/compat-openssl11-1.1.1k-4.el9.x86_64.rpm
openiamrepo/mariadb/mariadb-connector-c-3.1.11-2.el8_3.x86_64.rpm
openiamrepo/mariadb/perl-podlators-4.11-1.el8.noarch.rpm
openiamrepo/mariadb/perl-Exporter-5.72-396.el8.noarch.rpm
openiamrepo/mariadb/mariadb-server-utils-10.3.39-1.module+el8.8.0+19673+72b0d35f.x86_64.rpm
openiamrepo/mariadb/perl-Math-Complex-1.59-422.el8.noarch.rpm
openiamrepo/mariadb/perl-Text-ParseWords-3.30-395.el8.noarch.rpm
openiamrepo/mariadb/perl-Digest-MD5-2.55-396.el8.x86_64.rpm
openiamrepo/mariadb/libaio-0.3.112-1.el8.x86_64.rpm
openiamrepo/mariadb/perl-File-Path-2.15-2.el8.noarch.rpm
openiamrepo/mariadb/mariadb-server-10.3.39-1.module+el8.8.0+19673+72b0d35f.x86_64.rpm
openiamrepo/mariadb/perl-PathTools-3.74-1.el8.x86_64.rpm
openiamrepo/mariadb/perl-Pod-Escapes-1.07-395.el8.noarch.rpm
openiamrepo/mariadb/perl-libs-5.26.3-422.el8.x86_64.rpm
Would you like to install MariaDB RDBMS locally? \[y/n\]:Last metadata expiration check: 0:00:56 ago on Wed 15 Oct 2025 03:56:04 PM +01.
Error:
Problem 1: package perl-B-1.80-481.1.el9_6.x86_64 from System conflicts with perl-interpreter < 4:5.30.1-451 provided by perl-interpreter-4:5.26.3-422.el8.x86_64 from commandlinecommandlinecommandlinecommandline
* conflicting requests
* problem with installed package perl-B-1.80-481.1.el9_6.x86_64
Problem 2: cannot install both perl-libs-4:5.26.3-422.el8.xcommandlinecommandline6_64 from commandline and perl-libs-4:5.32.1-481.1.el9_6.x86_64 from System
* package foomatic-4.0.13-19.el9.x86_64 from System requires perl(:MODULE_COMPAT_5.32.1), but none of the providers can be installed
* problem with installed package foomatic-4.0.13-19.el9.x86_64
Problem 3: package perl-URI-1commandlinecommandline73-3.el8.noarch from commandline requires perl(:MODULE_COMPAT_5.26.2), but none of the providers can be installed
* cannot install both perl-libs-4:5.26.3-422.el8.x86_64 from openiam-local and perl-libs-4:5.32.1-481.1.el9_6.x86_64 from System
* cannot install both perl-lcommandlinecommandlinebs-4:5.26.3-422.el8.x86_64 from commandline and perl-libs-4:5.32.1-481.1.el9_6.x86_64 from System
* package perl-AutoLoader-5.74-481.1.el9_6.noarch from System requires perl(:MODULE_COMPAT_5.32.1), but none of the providers can be installed
* problem with installed package perl-AutoLoader-5.74-481.1.el9_6.noarch
Problem 4: package perlcommandlinecommandlineUnicode-Normalize-1.25-396.el8.x86_64 from commandline requires perl(:MODULE_COMPAT_5.26.2), but none of the providers can be installed
* pcommandlinecommandlineckage perl-Unicode-Normalize-1.25-396.el8.x86_64 from commandline requires libperl.so.5.26()(64bit), but none of the providers can be installed
* cannot install both perl-libs-4:5.26.3-422.el8.x86_64 from openiam-local and perl-libs-4:5.32.1-481.1.el9_6.x86_64 frocommandlinecommandline System
* cannot install both perl-libs-4:5.26.3-422.el8.x86_64 from commandline and perl-libs-4:5.32.1-481.1.el9_6.x86_64 from System
* package perl-Class-Struct-0.66-481.1.el9_6.noarch from System requires perl(:MODULE_COMPAT_5.32.1), but none of the providers can be installed
* problem with installed package perl-Class-Struct-0.66-481commandlinecommandline1.el9_6.noarch
Problem 5: package perl-Time-Local-1:1.280-1.el8.noarch from commandline requires perl(:MODULE_COMPAT_5.26.2), but none of the providers can be installed
commandline81.1.el9_6.x86_64
* cannot install both perl-libs-4:5.26.3-422.el8.x86_64 from openiam-lcommandlinecal and perl-libs-4:5.32.1-commandline81.1.el9_6.x86_64 from System
* package perl-DBD-SQLite-1.66-5.el9.x86_64 from System requires perl(:MODULE_COMPAT_5.32.1), but none of the providers can be installed
* package perl-DBD-SQLite-1.66-5.el9.x86_64 from System requires libperl.so.5.32()(64bit), but none of the providers can be installed
* commandlineroblem with installed packacommandlinee perl-DBD-SQLite-1.66-5.el9.x86_64
Problem 6: package perl-threads-shared-1.58-2.el8.x86_64 from commandlicommandlinee requires perl(:MODULE_COMcommandlineAT_5.26.2), but none of the providers can be installed
* package perl-threads-shared-1.58-2.el8.x86_64 from commandline requires libperl.so.5.26()(64bit), but none of the providers can be installed
* cannot install both perl-libs-4:5.2commandline.3-422.el8.x86_64 from opencommandlineam-local and perl-libs-4:5.32.1-481.1.el9_6.x86_64 from System
* package perl-DynaLoader-1.47-481.1.el9_6.x86_64 from System requires perl(:MODULE_COMPAT_5.32.1), but none of the providers can be instalcommandlinecommandlineed
* conflicting requestscommandline
* problem with installed package perl-DynaLoader-1.47-481.1.el9_6.x86_64
Problem 7: packagecommandlineperl-threads-1:2.21-2.el8.x86_64 from commandlinecommandline requires perl(:MODULE_COMPAT_5.26.2), but none of commandlinehe providers can be installed
* package perl-threads-1:2.21-2.el8.x86_64 from commandline requires libperl.so.5.26()(64bit), but none of the providers commandlinean be installed
* cannot install both perl-libs-commandline:5.26.3-422.el8.x86_64 from openiam-local and perl-libs-4:5.32.1-481.1.el9_6.x86_64 from System
* package perl-Fcntl-1.13-481.1.el9_6.x86_64 from System requires perl(:MODULE_COMPAT_5.32.1), but none of the providers can be installed
* package perl-Fcntl-1.13-481.1.el9_6.x86_64 from System requires libperl.so.5.32(commandline(64bit), but none of the providers can be installcommandlined
* problem with installed package perl-Fcntl-1.13-481.1.el9_6.x86_64
Problem 8: package perl-Text-Tabs+Wrap-2013.0523-395.el8.noarch from commandline requires perl(:MODULE_COMPAT_5.26.2), but commandlineone of the providers can be installed
* cannot icommandlinestall both perl-libs-4:5.26.3-422.el8.x86_64 from openiam-local and perl-libs-4:5.32.1-481.1.el9_6.x86_64 from System
* package perl-File-Basename-2.85-481.1.el9_6.noarch from System requires pcommandlinerl(:MODULE_COMPAT_5.32.1), but none of the providcommandliners can be installed
* problem with installed package perl-File-Basename-2.85-481.1.el9_6.noarch
Problem 9: package perl-Text-ParseWords-3.30-395.el8.noarch from commandline requires perl(:MODULcommandline_COMPAT_5.26.2), but none of the providers can becommandlineinstalled
* package perl-File-Find-1.37-481.commandline.el9_6.noarch from System requires perl(:MODULE_COMPATcommandline5.32.1), but none of the providers can be installed
* problem with installed package perl-File-Find-1.37-481.1.el9_6.noarch
Problem 10: package perl-Term-Cap-1.17-395.el8.noarch from commandlincommandline requires perl(:MODULE_COMPAT_5.26.2), but none ocommandline the providers can be installed
* package perl-Filcommandline-stat-1.09-481.1.el9_6.noarch from System requires percommandline(:MODULE_COMPAT_5.32.1), but none of the providers can be installed
* problem with installed package perl-File-stat-1.09-481.1.el9_6.noarch
Problem 11: package perl-Term-ANSIColor-4.06-396.el8.ncommandlinearch from commandline requires perl(:MODULE_COMPcommandlineT_5.26.2), but none of the providers can be installed
* pcommandlineckage perl-FileHandle-2.03-481.1.el9_6commandlinenoarch from System requires perl(:MODULE_COMPAT_5.32.1), but none of the providers ccomman be installed
* problemcommandlinewith installed package perl-FileHandle-2.03-481.1.el9_6.noarch
Problem 12: package perl-Storable-1:3.11-3.el8.x86_64 from commandline requires libperl.so.5.26()(64bit), but none of the providers can be installed
* package pcommandlinerl-Storable-1:3.11-3.el8.x86_64 from commacommandlinedline requires perl(:MODULE_COMPAT_5.26.3), but none of the providers can be installed
* cannot install both perl-libs-4:5.26.3-422.el8.x86_64 from commandline and perl-libs-4:5.32.1-481commandline1.el9_6.x86_64 from System
* packagcommandline perl-Getopt-Std-1.12-481.1.el9_6.noarch from System requires perl(:MODULE_COMPAT_5.32.1), but none ocommandline the providers can be installedcommandline
* problem with installed package perl-Getopt-Std-1.12-481.1.el9_6.noarch
Problem 13: package perl-Socket-4:2.027-3.el8.x86_64 from commandline requires libperl.so.5.26()(64bit), but none of the provicommandlineers can be installed
* package pecommandline.x86_64l-Socketcommandline4:2.027-3.el8.x86_64 from commandline requires perl(:MODULE_COMPAT_5.26.3), but none of the providers can be installed
* cannot install both perl-libs-4:5.26.3-422.el8.x86_64 commandlinerom commandline and perl-libs-4:5.32.1-481.1.el9\_commandline.x86_64 from System
* package perl-IPC-Open3-1.21-481.1.el9_6.noarch from System requires perl(:MODcommandlineLE_COMPAT_5.32.1), but none of the providers can bcommandline installed
* problem with installed package perl-IPC-Open3-1.21-481.1.el9_6.noarch
Problem 14: package perl-Scalar-List-Utils-3:1.49-2.el8.x86_64 from commandline requires perl(:commandlineODULE_COMPAT_5.26.2), but none of the providers can be instalcommandlineed
* package perl-Scalar-List-Utils-3:1.49-2.el8.x86_64 from commandline requires libperl.so.5.26()(64bit), but none of the providers can be installed
* package perl-NDBM_File-1.1commandline-481.1.el9_6.x86_64 from System requires perl(:MODULE_CcommandlineMPAT_5.32.1), but none of the providers can be installed
* package perl-NDBM_File-1.15-481.1.el9_6.x86_64 from System requires libperl.so.5.32()(64bit), but none of the providers can be installed
* conflicting commandlineequests
* problem with installed package perl-NDBM_File-1.15commandline481.1.el9_6.x86_64
Problem 15: package perl-Pod-Usage-4:1.69-395.el8.noarch from commandline requires perl(:MODULE_COMPAT_5.26.2), but none of the providers can be installed
* cannot install both perl-libs-4:5.26.3-422.el8.x86_64 from commandline and perl-libs-4:5.32.1-481.1.el9_6.x86_64 frocommandline System
* package perl-POSIX-1.94-481.1.el9_6.x86_64 fcommandlineom System requires perl(:MODULE_COMPAT_5.32.1), but none of the providers can be installed
* package perl-POSIX-1.94-481.1.el9_6.x86_64 from System requires libperl.so.5.32()(64bit), but none of the providers can be installed
* commandline
* problem with installed pacommandlinekage perl-POSIX-1.94-481.1.el9_6.x86_64
Problem 16: package perl-Pod-Simple-1:3.35-395.el8.noarch from commandline requires perl(:MODULE_COMPAT_5.26.2), but none commandlineithf the providers can be installed
* cannot install both perl-libs-4:5.26.3-422.el8.x86_64 from openiam-local and perl-libscommandline4:5.32.1-481.1.el9_6.x86_64 from System
* cannot install both perl-lcommandlinebs-4:5.26.3-422.el8.x86_64 from commandline and perl-libs-4:5.32.1-481.1.el9_6.x86_64 from System
* package perl-SelectSaver-1.commandlinerom2-481.1.el9_6.noarch from System requires perl(:MODULE_COMPAT_5.32.1),commandlinebut none of the providers can be installed
* problem commandlineith installed package perl-SelectSaver-1.02-481.1.el9_6.noarch
Problem 17: package perl-Pod-Perldoc-3.28-396.el8.noarch from commandline requires perl(:MODULE_COMPAT_5.26.2), but none of the providers can be installed
* cannot install both perl-libs-4:5.26commandline3-422.el8.x86_64 from openiam-local and perl-libs-4:5.32.1-481.1.el9_6.x86_64 commandlinerom System
* package perl-Symbol-1.08-481.1.el9_6.noarch from System requircommandlines perl(:MODULE_COMPAT_5.32.1), but none of the providers can be installed
* ccommandlinenflicting requests
* problem with installed package perl-Symbol-1.08-481.1.el9_6.noarch
Problem 18: package perl-podlators-4.11-1.el8.noarch from commandline requires perl(:MODULE_COMPAT_5.26.2), but none of the providers can be installed
* cannot install bcommandlineth perl-libs-4:5.26.3-422.el8.x86_64 from openiam-local and perl-libs-4:5.32.1commandline481.1.el9_6.x86_64 from System
* package perl-base-2.27-481.1.el9_6.nocommandlinerch from System requires perl(:MODULE_COMPAT_5.32.1), but none of the providers cancommandlinebe installed
* problem with installed package perl-base-2.27-481.1.el9_6.noarch
Problem 19: package perl-Pod-Escapes-1:1.07-395.el8.noarch from commandline requires perl(:MODULE_COMPAT_5.26.2), but none of the providers can be installed
* cancommandlineot install both perl-libs-4:5.26.3-422.el8.x86_64 from openiam-locacommandline and perl-libs-4:5.32.1-481.1.el9_6.x86_64 from System
* commandlinecannot install both perl-libs-4:5.26.3-422.el8.x86_64 from commandline and pecommandlinel-libs-4:5.32.1-481.1.el9_6.x86_64 from System
* package perl-if-0.60.800-481.1.el9_6.noarch from System requires perl(:MODULE_COMPAT_5.32.1), but none of the providers can be installed
* confliccommandlineing requests
* problem with installed package perl-if-0.60.800-481.1.el9_6.nocommandlinerch
Problem 20: package perl-PathTools-3.74-1.el8.x86_64 from commandline requires perl(:MODULE_COMPAT_5.26.2), but none of the providers can be installed
* package perl-PathTools-3.74-1.el8.x86_64 from commandline requires libperl.so.5.26()(64bit), but ncommandlinene of the providers can be installed
* cannot install both perl-libs-4:5.26.3commandline422.el8.x86_64 from openiam-local and perl-libs-4:5.32.1-481.1.el9_6.x86_64 from System
* cannot install both perl-libs-4:5.26.3-422.el8.x86_64 from commandline and perl-libs-4:5.32.1-481.1.el9commandline6.x86_64 from System
* package perl-locale-1.09-481.1.el9_6.noarch from System requirescommandlineperl(:MODULE_COMPAT_5.32.1), but none of the providers can be installed
* problem with installed package perl-locale-1.09-481.1.el9_6.noarch
Problem 21: package perl-parent-1:0.237-1.el8.noarch from commandline requires perl(:MODULE_COMPAT_5.26.2), but none of the providers can be installed
* cannot install both perl-libs-4:5.26.3-422.el8.x86_64 from openiam-local and perl-libs-4:5.32.1-48commandline.1.el9_6.x86_64 from System
* cannot install both perl-libs-4:5.26.3-42commandline.el8.x86_64 from commandline and perl-libs-4:5.32.1-481.1.el9_6.x86_64 fromcommandline System
* package perl-mro-1.23-481.1.el9_6.x86_64 from System requires perl(:MODULE_COMcommandlineAT_5.32.1), but none of the providers can be installed
* package perl-mro-1.23-481.1.el9_6.x86_64 from System requires libperl.so.5.32()(64bit), but none of the providers can be installed
* concommandlinelicting requests
* problem with installed package perl-mro-1.23-481.1.el9_6.xcommandline6_64
Problem 22: package perl-Net-SSLeay-1.88-2.module+el8.6.0+13392+f0897f98.x86_64 from commandline requires libperl.so.5.26()(64bit), but none of the providers can be installed
* package perl-Net-SSLeay-1.88-2.module+el8.6.0+13392+f0897f98.x86_64 from commandline requires perl(:MODULE\_commandlineOMPAT_5.26.3), but none of the providers can be installed
* cannot install bocommandlineh perl-libs-4:5.26.3-422.el8.x86_64 from openiam-local and perl-libs-4:5.32.1-481.1.el9_6.x86_64 from System
* cannot install both perl-libs-4:5.26.3-422.el8.x86_64 from commandline and perl-libs-4:5.32.1commandline481.1.el9_6.x86_64 from System
* package perl-overload-1.31-481.1.el9_6commandlinenoarch from System requires perl(:MODULE_COMPAT_5.32.1), but none of the providers can be installed
* problem with installed package perl-overload-1.31-481.1.el9_6.noarch
Problem 23: package perl-Mozilla-CA-20160104-7.module+el8.3.0+6498+9eecfe51.noarch from comcommandlineandline requires perl(:MODULE_COMPAT_5.26.3), but none of the provicommandlineers can be installed
* cannot install both perl-libs-4:commandline.26.3-422.el8.x86_64 from openiam-local and perl-libs-4:5.32.1-481.1.el9_6.x86commandline64 from System
* package perl-overloading-0.02-481.1.el9_6.noarch fcommandlineom System requires perl(:MODULE_COMPAT_5.32.1), but none of the providers can be incommandlinetalled
* problem with installed package perl-overloading-0.02-481.1.el9_6.noarch
Problem 24: package perl-MIME-Base64-3.15-396.el8.x86_64 from commandline requires perl(:MODULE_COMPAT_5.26.2), but none of the providers can be installcommandd
* package perl-MIME-Base64-3.15-396.el8.x86_64 from commandline requires lcommandlinebperl.so.5.26()(64bit), but none of the providers can be installed
* cannot inscommandlineall both perl-libs-4:5.26.3-422.el8.x86_64 from commandline ancommandline perl-libs-4:5.32.1-481.1.el9_6.x86_64 from System
* package perl-subs-1.03-481.1.el9_6.noarch from System requires perl(:MODULE_COMPAT_5.32.1), but none of the providers can be installed
* problem with installed package perl-subs-1.03-481.1.el9_6.noarch
Problemcommandline25: package perl-Math-Complex-1.59-422.el8.noarch from commandcommandlineine requires perl(:MODULE_COMPAT_5.26.3), but none of the providers can be installed
* cannot install both perl-libs-4:5.26.3-422.el8.x86_64 from openiam-local and perl-libs-4:5.32.1-481.1.el9_6.x86_64 frcommandlinem System
* cannot install both perl-libs-4:5.26.3-422.el8.x86_64 frcommandlinem commandline and perl-libs-4:5.32.1-481.1.el9_6.x86_64 from System
* package perl-vars-1.05-481.1.el9_6.noarch from System requires perl(:MODULE_COMPAT_5.32.1), but none of the providers can be installed
* problem with installed package perl-vars-1.05-481.commandline.el9_6.noarch
Problem 26: package perl-Math-BigInt-1:1.9998.11-7.el8.noarccommandline from commandline requires perl(:MODULE_COMPAT_5.26.3), but none of the providers can be installed
* cannot install both perl-libs-4:5.26.3-422.el8.x86_64 from openiam-local and perl-libs-4:5.commandline2.1-481.1.el9_6.x86_64 from System
* cannot install both perl-libs-4:5.26.3-42commandline.el8.x86_64 from commandline and perl-libs-4:5.32.1-481.1.el9_6.x86_64 from System
* package python3-perf-5.14.0-570.49.1.el9_6.x86_64 from System requires libperl.so.5.32()(64bit), but none of the providers can be installed
* problem with installed package python3-perf-5.14.0-570.49.1.el9_6.x86_64
Problem 27: package perl-macros-4:5.26commandline3-422.el8.x86_64 from commandline requires perl(:MODULE_COMPAT_5.26.3), bcommandlinet none of the providers can be installed
* cannot installcommandlineboth perl-libs-4:5.26.3-422.el8.x86_64 from commandline and perl-libs-4:5.32.1-481.1commandlineel9_6.x86_64 from System
* package pnm2ppa-1:1.04-52.el9.x86_64 from System requires foomatic, but none of the providers can be installed
* problem with installed package pnm2ppa-1:1.04-52.el9.x86_64
Problem 28: package perl-libnet-3.11-3.el8.noarch from commandline requires perl(:MODULE_COMPAT_5.26.2), but none of the providers can be installed
* package rasdaemon-0.6.7-18.el9.x86_64 from System requires perl-DBD-SQLite, but none of the providers can be installed
* problem with installed package commandlineasdaemon-0.6.7-18.el9.x86_64
Problem 29: problem with installed package pecommandlinel-Sys-Hostname-1.23-481.1.el9_6.x86_64
* package perl-Sys-Hostname-1.23-481.1.el9_6.x86_64 from System requires perl(:MODULE_COMPAT_5.32.1), but none of the providers can be installed
* package percommandline-Sys-Hostname-1.23-481.1.el9_6.x86_64 from System requires libperl.so.5.32()(64commandlineit), but none of the providers can be installed
* package perl-Sys-Hostname-1.23-481.el9.x86_64 from openiam-local requires perl(:MODULE_COMPAT_5.32.1), but none of the providers can be installed
* package perl-Sys-Hostname-1.23-481.el9.x86_64 from openiam-local requires libperl.so.5.32()(64bit), but none of the providers can be installed
* package perl-IO-Socket-SSL-2.066-4.module+el8.3.0+6446+594cad75.noarch fcommandlineom commandline requires perl(:MODULE_COMPAT_5.26.3), but none of the procommandlineiders can be installed
* cannot install both perl-libs-4:5commandline26.3-422.el8.x86_64 from cocommandline.el9_6.x86_64mandline and perl-libs-4:5.32.1-481.1.el9_6.x86_64 fromcommandline System
Problem 30: probcommandline4em with installed package perl-File-Copy-2.34-481.1.el9_6.noarch
* package perl-File-Copy-2.34-481.1.el9_6.noarch from System requires perl(:MODULE_COMPAT_5.32.1), but none of the providers can be installed
* package perl-File-Copy-2.34-481.el9.noarch from openiam-local requires perl(:MODULE_COMPAT_5.32.1), but none of the providers can be installed
* package perl-IO-Socket-IP-0.39-5.el8.noarch from commandline requires perl(:MODULE_COMPAT_5.26.2), but none of the providers can be installed
* commandlinecannot install both perl-libs-4:5.26.3-422.el8.x86_64 from commandline and perl-libs-4:5.32.1-481.commandline.el9_6.x86_6commandline from System
Problem 31: problem with installed package perl-DBD-MariaDB-1.21-16.el9_0.x86\_commandline4
* package perl-DBD-MariaDB-1.21-16.el9_0.x86_64 from System requires perl(:MODULE_COMPAT_5.32.1), but none of the providers can be installed
* packacommandlinee perl-DBD-MariaDB-1.21-16.el9_0.x86_64 from System requires libperl.so.5.32()(64bit), but none of the providers can be instalcommandlineed
* package perl-DBD-MariaDB-1.21-16.el9_0.x86_64 from openiam-local requires perl(:MODULE_COMPAT_5.32.1), but none of the providers can be installed
* package perl-DBD-MariaDB-1.21-16.el9_0.x86_64 from openiam-local requires libperl.so.5.32()(64bit), but none of the providers can be installed
* package perl-IO-1.38-422.el8.x86_64 from commandline requires libperl.so.5.26()(64bit), but none of the providers can be installed
* package perl-IO-1.38-422.el8.x86_64 from commandline requires perl(:MODULE_COMPAT_5.26.3), but none of the providers can be installed
(try to add ‘–allowerasing’ to command line to replace conflicting packages or ‘–skip-broken’ to skip uninstallable packages or ‘–nobest’ to use not only best candidate packages)
Database: jdbc:mysql://localhost:3306/openiam?autoReconnect=true&useUnicode=true&characterEncoding=utf8&connectionCollation=utf8_general_ci&serverTimezone=UTC (MariaDB 10.5)
Creating Schema History table `openiam`.`flyway_schema_history` with baseline …
Successfully baselined schema with version: 2.3.0.0
Successfully validated 1227 migrations (execution time 00:00.652s)
Current version of schema `openiam`: 2.3.0.0
Migrating schema `openiam` to version “2.3.0.0.001 - mysql schema common”
Migrating schema `openiam` to version “2.3.0.0.002 - mysql schema security”
Migrating schema `openiam` to version “2.3.0.0.003 - mysql idm data”
Migrating schema `openiam` to version “3.0.0.0.001 - alter table attribute map”
Migrating schema `openiam` to version “3.0.0.0.002 - create resource many to many mapping”
Migrating schema `openiam` to version “3.0.0.0.003 - create group many to many mapping”
Migrating schema `openiam` to version “3.0.0.0.004 - migrate role id”
Migrating schema `openiam` to version “3.0.0.0.005 - migrate resource role mappings”
Migrating schema `openiam` to version “3.0.0.0.006 - create role many to many mapping”
Migrating schema `openiam` to version “3.0.0.0.007 - create group and role name constraints”
Migrating schema `openiam` to version “3.0.0.0.008 - add authorization data to resources”
Migrating schema `openiam` to version “3.0.0.0.009 - migrate menus to resources”
Migrating schema `openiam` to version “3.0.0.0.010 - fix resource name and type”
Migrating schema `openiam` to version “3.0.0.0.011 - add url protector column to res”
Migrating schema `openiam` to version “3.0.0.0.012 - fix group name”
Migrating schema `openiam` to version “3.0.0.0.013 - add fk to users”
Migrating schema `openiam` to version “3.0.0.0.014 - remove obsolete res and role fields”
Migrating schema `openiam` to version “3.0.0.0.015 - fix role name”
Migrating schema `openiam` to version “3.0.0.0.016 - update menu urls”
Migrating schema `openiam` to version “3.0.0.0.017 - role menus”
Migrating schema `openiam` to version “3.0.0.0.018 - fix group name”
Migrating schema `openiam` to version “3.0.0.0.019 - drop deprecated group columns”
Migrating schema `openiam` to version “3.0.0.0.020 - group menus”
Migrating schema `openiam` to version “3.0.0.0.021 - create group categories”
Migrating schema `openiam` to version “3.0.0.0.022 - fix id lenght metadata category”
ERROR: Migration of schema `openiam` to version “3.0.0.0.022 - fix id lenght metadata category” failed! Please restore backups and roll back database and code!
ERROR: Script V3.0.0.0.022__fix_id_lenght_metadata_category.sql failed
SQL State : HY000
Error Code : 1833
Message : (conn=12) Cannot change column ‘TYPE_ID’: used in a foreign key constraint ‘openiam/FK_CATEGORY_METADATA_TYPE’ of table ‘openiam/CATEGORY_TYPE’
Location : /usr/local/openiam/conf/schema/mysql/openiam/3.0.0.0/V3.0.0.0.022__fix_id_lenght_metadata_category.sql (/usr/local/openiam/conf/schema/mysql/openiam/3.0.0.0/V3.0.0.0.022__fix_id_lenght_metadata_category.sql)
Line : 2
Statement : Run Flyway with -X option to see the actual statement causing the problem
## Caused by: Script V3.0.0.0.022__fix_id_lenght_metadata_category.sql failed
SQL State : HY000
Error Code : 1833
Line : 2
Caused by: java.sql.SQLTransientConnectionException: (conn=12) Cannot change column ‘TYPE_ID’: used in a foreign key constraint ‘openiam/FK_CATEGORY_METADATA_TYPE’ of table ‘openiam/CATEGORY_TYPE’
Caused by: org.mariadb.jdbc.internal.util.exceptions.MariaDbSqlException: Cannot change column ‘TYPE_ID’: used in a foreign key constraint ‘openiam/FK_CATEGORY_METADATA_TYPE’ of table ‘openiam/CATEGORY_TYPE’
Caused by: java.sql.SQLException: Cannot change column ‘TYPE_ID’: used in a foreign key constraint ‘openiam/FK_CATEGORY_METADATA_TYPE’ of table ‘openiam/CATEGORY_TYPE’
This is the init log. I would be very grateful if you could find a way to resolve this. This is the no internet installation
