Error in janusgraph
Hello!
After a successful install process, OpenIAM can’t start properly, trying `openiam-cli start` produces the following messages:
Starting openiam
The infra.status is red, let's give it a try to check the infra and change the status...
  % Total    % Received % Xferd  Average Speed   Time    Time     Time  Current
                                 Dload  Upload   Total   Spent    Left  Speed
100   816  100   801  100    15  22250    416 --:--:-- --:--:-- --:--:-- 23314
100   202  100   202    0     0   9619      0 --:--:-- --:--:-- --:--:--  9619
100   816  100   801  100    15  29666    555 --:--:-- --:--:-- --:--:-- 31384
100   221  100   221    0     0   9208      0 --:--:-- --:--:-- --:--:--  9208
Check that infra is up and Running
0
100   297  100   297    0     0  14850      0 --:--:-- --:--:-- --:--:-- 14850
Vault alive...
Vault is ready to use. Continue...
0
Datacenter: datacenter1
Status=Up/Down
|/ State=Normal/Leaving/Joining/Moving
--  Address    Load      Tokens  Owns (effective)  Host ID                               Rack
UN  127.0.0.1  1.36 MiB  256     100.0%            00ed44b4-eb16-47a1-9d27-3d9ba72e8e6f  rack1
Cassandra alive
Cassandra is ready to use. Continue...
0
WARNING: An illegal reflective access operation has occurred
WARNING: Illegal reflective access by org.codehaus.groovy.vmplugin.v7.Java7$1 (file:/usr/local/openiam/janusgraph/lib/groovy-2.5.7-indy.jar) to constructor java.lang.invoke.MethodHandles$Lookup(java.lang.Class,int)
WARNING: Please consider reporting this to the maintainers of org.codehaus.groovy.vmplugin.v7.Java7$1
WARNING: Use --illegal-access=warn to enable warnings of further illegal reflective access operations
WARNING: All illegal access operations will be denied in a future release
Exception in thread "main" java.lang.UnsatisfiedLinkError: Could not load library. Reasons: [no jansi in java.library.path: [/usr/java/packages/lib, /usr/lib64, /lib64, /lib, /usr/lib], /tmp/libjansi-64-12696956196826987406.so: /tmp/libjansi-64-12696956196826987406.so: failed to map segment from shared object]
        at org.fusesource.hawtjni.runtime.Library.doLoad(Library.java:182)
        at org.fusesource.hawtjni.runtime.Library.load(Library.java:140)
        at org.fusesource.jansi.internal.CLibrary.<clinit>(CLibrary.java:42)
        at org.fusesource.jansi.AnsiConsole.wrapOutputStream(AnsiConsole.java:48)
        at org.fusesource.jansi.AnsiConsole.<clinit>(AnsiConsole.java:38)
        at java.base/java.lang.Class.forName0(Native Method)
        at java.base/java.lang.Class.forName(Unknown Source)
        at org.codehaus.groovy.vmplugin.v7.Selector$MethodSelector.getMetaClass(Selector.java:567)
        at org.codehaus.groovy.vmplugin.v7.Selector$MethodSelector.setCallSiteTarget(Selector.java:986)
        at org.codehaus.groovy.vmplugin.v7.IndyInterface.selectMethod(IndyInterface.java:230)
        at org.apache.tinkerpop.gremlin.console.Colorizer.installAnsi(Colorizer.groovy:32)
        at org.codehaus.groovy.vmplugin.v7.IndyInterface.selectMethod(IndyInterface.java:234)
        at org.apache.tinkerpop.gremlin.console.Console.<clinit>(Console.groovy:60)
Janusgraph has problems
Warning: Stopping janusgraph.service, but it can still be activated by:
  janusgraph.timer
1
Exception in thread "main" java.lang.UnsatisfiedLinkError: Could not load library. Reasons: [no jansi in java.library.path: [/usr/java/packages/lib, /usr/lib64, /lib64, /lib, /usr/lib], /tmp/libjansi-64-9882599154020807573.so: /tmp/libjansi-64-9882599154020807573.so: failed to map segment from shared object]
  janusgraph.timer
2
Exception in thread "main" java.lang.UnsatisfiedLinkError: Could not load library. Reasons: [no jansi in java.library.path: [/usr/java/packages/lib, /usr/lib64, /lib64, /lib, /usr/lib], /tmp/libjansi-64-11776021526674679011.so: /tmp/libjansi-64-11776021526674679011.so: failed to map segment from shared object]
  janusgraph.timer
  janusgraph.timer3
Exception in thread "main" java.lang.UnsatisfiedLinkError: Could not load library. Reasons: [no jansi in java.library.path: [/usr/java/packages/lib, /usr/lib64, /lib64, /lib, /usr/lib], /tmp/libjansi-64-17409307434635029713.so: /tmp/libjansi-64-17409307434635029713.so: failed to map segment from shared object]
  janusgraph.timer
4
Exception in thread "main" java.lang.UnsatisfiedLinkError: Could not load library. Reasons: [no jansi in java.library.path: [/usr/java/packages/lib, /usr/lib64, /lib64, /lib, /usr/lib], /tmp/libjansi-64-1776717681949098262.so: /tmp/libjansi-64-1776717681949098262.so: failed to map segment from shared object]
  janusgraph.timer
5
Exception in thread "main" java.lang.UnsatisfiedLinkError: Could not load library. Reasons: [no jansi in java.library.path: [/usr/java/packages/lib, /usr/lib64, /lib64, /lib, /usr/lib], /tmp/libjansi-64-981285500806417404.so: /tmp/libjansi-64-981285500806417404.so: failed to map segment from shared object]
  janusgraph.timer
6
Janus is Dead. Can't continue!
Something is wrong with the infrastructure, check all services manually, run them and do openiam-cli start again
Below system info:
/etc/os-release
cat /etc/os-release
NAME="Rocky Linux"
VERSION="9.6 (Blue Onyx)"
ID="rocky"
ID_LIKE="rhel centos fedora"
VERSION_ID="9.6"
PLATFORM_ID="platform:el9"
PRETTY_NAME="Rocky Linux 9.6 (Blue Onyx)"
ANSI_COLOR="0;32"
LOGO="fedora-logo-icon"
CPE_NAME="cpe:/o:rocky:rocky:9::baseos"
HOME_URL="https://rockylinux.org/"
VENDOR_NAME="RESF"
VENDOR_URL="https://resf.org/"
BUG_REPORT_URL="https://bugs.rockylinux.org/"
SUPPORT_END="2032-05-31"
ROCKY_SUPPORT_PRODUCT="Rocky-Linux-9"
ROCKY_SUPPORT_PRODUCT_VERSION="9.6"
REDHAT_SUPPORT_PRODUCT="Rocky Linux"
REDHAT_SUPPORT_PRODUCT_VERSION="9.6"
Janusgraph service reports RUNNING status:
systemctl status janusgraph
● janusgraph.service - JanusGraph
     Loaded: loaded (/etc/systemd/system/janusgraph.service; disabled; preset: disabled)
     Active: active (running) since Wed 2025-09-24 15:07:50 -03; 4min 38s ago
TriggeredBy: ● janusgraph.timer
       Docs: http://janusgraph.org/
    Process: 371658 ExecStart=/bin/bash -c /usr/local/openiam/janusgraph/bin/gremlin-server.sh start (code=exited, status=0/SUCCESS)
   Main PID: 371685 (java)
      Tasks: 48 (limit: 203268)
     Memory: 564.2M
        CPU: 15.763s
     CGroup: /system.slice/janusgraph.service
             └─371685 /usr/local/openiam/jdk//bin/java -server -Djanusgraph.logdir=/usr/local/openiam/janusgraph/logs -Dlog4j.configuration=file:/usr/local/openiam/janusgraph/conf/gremlin-server/log4j->
Sep 24 15:07:50 q-sec-iopeniam-01.sec.telecel.net.py systemd[1]: Starting JanusGraph...
Sep 24 15:07:50 q-sec-iopeniam-01.sec.telecel.net.py bash[371658]: Server started 371685.
Sep 24 15:07:50 q-sec-iopeniam-01.sec.telecel.net.py systemd[1]: Started JanusGraph.
Tried the following: dnf install jansi but nothing changes
Any help will be appreciated
Thanks in advance!
We had a similar issue with our installation, due to security controls.
You may need to move the /tmp dir used by the janusgraph service to a location that is mounted without NOEXEC, and accessible by the openiam user (EX: /usr/local/openiam/tmp/).
Editing these two files solved the issue for us.
vi /usr/local/openiam/janusgraph/bin/gremlin.sh
## near line 122, append new option...
##JAVA_OPTIONS="${JAVA_OPTIONS} -Duser.working_dir=${USER_DIR} -Dtinkerpop.ext=${USER_EXT_DIR:-${SYSTEM_EXT_DIR}} -Dlog4j.configuration=conf/log4j-console.properties -Dgremlin.log4j.level=$GREMLIN_LOG_LEVEL -javaagent:$LIB/jamm-0.3.0.jar -Dgremlin.io.kryoShimService=org.janusgraph.hadoop.serialize.JanusGraphKryoShimService"
JAVA_OPTIONS="${JAVA_OPTIONS} -Duser.working_dir=${USER_DIR} -Dtinkerpop.ext=${USER_EXT_DIR:-${SYSTEM_EXT_DIR}} -Dlog4j.configuration=conf/log4j-console.properties -Dgremlin.log4j.level=$GREMLIN_LOG_LEVEL -javaagent:$LIB/jamm-0.3.0.jar -Dgremlin.io.kryoShimService=org.janusgraph.hadoop.serialize.JanusGraphKryoShimService -Djava.io.tmpdir=/usr/local/openiam/tmp"
vi /usr/local/openiam/janusgraph/bin/gremlin-server.sh
## near line 124, append new option...
  #JAVA_OPTIONS="-Xms512m -Xmx512m -javaagent:$JANUSGRAPH_LIB/jamm-0.3.0.jar -Dgremlin.io.kryoShimService=org.janusgraph.hadoop.serialize.JanusGraphKryoShimService"
  JAVA_OPTIONS="-Xms512m -Xmx512m -javaagent:$JANUSGRAPH_LIB/jamm-0.3.0.jar -Dgremlin.io.kryoShimService=org.janusgraph.hadoop.serialize.JanusGraphKryoShimService -Djava.io.tmpdir=/usr/local/openiam/tmp"
We have permissions set on the new tmp dir location as:
drwxr-xr-x.  2 openiam openiam          6 Sep  7 07:05 tmp
Then systemctl restart janusgraph
Hello!
That solved our issue
Thank you very much!
