JDBC Synchronization not creating a User Identity entry
Hello,
I have configured a JDBC Synchronization, but when I run it there is a strange behavior:
I can correctly see the new user attributes, but I cannot see the new Account entry listed under “User Identities”, as is for other managed systems:
Can anyone help me to solve the issue?
Hello Francesco,
Are you using the default (classic) view which shows all of the fields, or a template view?
Also, can you please share your policy map?
Hello Ameet,
I am using the classic view, regarding the policy map there is any configured policy right now.
Am I supposed to configure one?
Regards,
Francesco
Hello Francesco,
In your transformation script you may be missing the login object for the JDBC-based managed system. As an example, in our AD synch script we have the following code:
    String AD_MANAGED_SYS_ID = "active_dir_win02_managed_sys_id";
    if (KEEP_AD_ID && isNewUser) {
            println(" - Processing PrincipalName and DN")
            //attrVal = columnMap.get("sAMAccountName")
            if (attrVal) {
                // PRE-POPULATE THE USER LOGIN. IN SOME CASES THE COMPANY WANTS TO KEEP THE LOGIN THAT THEY HAVE
                // THIS SHOWS HOW WE CAN DO THAT
                def lg = new Login()
                lg.operation = AttributeOperationEnum.ADD
                lg.login = attrVal.value
                lg.managedSysId = "0"
                lg.setActive(true)
                pUser.principalList.add(lg)
                Login lg2 = new Login()
                lg2.operation = AttributeOperationEnum.ADD
                lg2.login = attrVal.value
                lg2.managedSysId = AD_MANAGED_SYS_ID
                lg2.setActive(true)
                pUser.principalList.add(lg2)
Please note the login object in the second part of the script – you need to add this to your transformation script. I will follow up with our team so that they add this to the out-of-the-box scripts.
Hello Ameet,
many thanks.
Can I ask you why there is a first login record set with managedSysId = “0”, what is the purpose of that?
Regards,
Francesco
Hello Francesco,
That managedSysId refers to the OpenIAM managed system. It is the only managed system that has a set value.
Hi @ameet_shah,
Where can I see the class for AttributeOperationEnum.ADD?
Thank you in advance for your support.
Hello Pamela,
Please refer to this link: AttributeOperationEnum (OpenIAM Identity Manager 4.2.1.13 API)
