Hello, how could I set the date and time of my area in OpenIAM? Because when a user makes a change in the logs it is reflected one hour less than the correct one.
Thank you very much.
Hello @lgc,
Thanks for the question. Just to clarify:
Are you looking to change the timezone of the OpenIAM backend services?
If yes, what type of installation do you have? (i.e., version, docker/rpm)
Yes
RPM installation.
Hello @lgc ,
The following commands can be used to update the server timezone:
sudo timedatectl set-timezone <Your_Timezone>
To check the current timezone:
timedatectl
After updating the timezone, the server OS log timestamps and cron job execution times will be updated accordingly and aligned with the configured timezone. Please proceed with caution.
It is generally recommended to configure the OS-level timezone during the initial server setup.
Hi,
The server Timezone is OK , but the problem is on:
conf/properties/datasource.properties
with variable:
jdbc.server.timezone=
Thanks !
Hello @lgc,
To fix this, set the jdbc.server.timezone variable in conf/properties/datasource.properties to match your database server’s timezone. For example:
jdbc.server.timezone=Europe/Madrid
Use a valid IANA timezone ID — you can find the full list here (https://en.wikipedia.org/wiki/List_of_tz_database_time_zones).
After saving the file, restart the OpenIAM services:
sudo systemctl restart openiam-esb
sudo systemctl restart openiam-ui
This should align the log timestamps correctly.
Please let me know if you have any questions.
